Too O-Ring or not to O-ring. That is the Question.
Originally posted by: sandbomber
Keith, less drag on a non o-ring chain for drag racing.
I am running a Yamaha steel 40 tooth 520 sprocket. I am running a RWR 520 pitch 17 tooth front. I am running an X-ring chain. It won't last as long as an O-ring I guess but it does have some of the maintenence advantages that an o-ring has.
I am a bit worried about the tensil strength though. I don't know what it is and I don't currently have a case saver with my 17 tooth sprocket. Those are problems I have to solve in the next couple of weeks.
Ron
Ron
Back to the thread topic: I've never seen a fast banshee (stoker, drag frame, etc..) run a O-ring chain. A non-o-ring chain weights about 1/3rd of a equal strength o-ring chain, due to the pins needing to be much longer on the o-ring chain. Its a proven fact that non-o-ring chains when clean has much less friction than o-ring or x-ring. For you DS owners who are converting to 520, you are doing yourself a huge rotational mass favor, but I believe that a non-o-ring chain when maintained properly will give you that little extra "edge". It comes down to what you want: less maintence, longer life, or little extra attention to cleaning and less rotational mass and friction.
#15
So to O-ring or not to O-ring, sounds like for me I am going with the not to. Scatter, what about you???
#17
"I am running a Yamaha steel 40 tooth 520 sprocket. I am running a RWR 520 pitch 17 tooth front. I am running an X-ring chain. It won't last as long as an O-ring I guess but it does have some of the maintenence advantages that an o-ring has.
Ron"
From what I've 'read', the x ring wears longer than oring or non ring and are the preference for street racing anyway. Less friction than oring and greater lube (2 surface seals). The xring lube factor must overcome friction advantages over the nonoring. That explains why HPR liked the nonoring chain for drag racing mainly. I would put it into a cost equation. Will the possible income from the marginal performance difference pay for the additional labor/parts/downtime?
Ron"
