crankcase breather question?
Old Mar 8, 2006 | 07:00 AM
albabomb's Avatar
Default crankcase breather question?
Does anyone get oil leaking out of the crankcase breather tube every now and then? I sometimes get oil that leaks out of the tube coming from the crankcase..........
Old Mar 8, 2006 | 10:12 AM
650VIPER's Avatar
Oh yes. I have a little catch can for it.
Old Mar 8, 2006 | 11:38 AM
FatHolly's Avatar
I run with no air box, so I was getting quite a bit a leaking here. I extended the case breather hose back to the snorkel between the filter and carb. There is a nub on the other side from the balance tube. I drilled a hole there and hooked up the extension from the case breather. I have not have a drip of oil there since.
Old Mar 8, 2006 | 12:33 PM
Scatterbrain's Avatar
Oh yea, Normal. re-routed mine out the back. Hey jed you got a pic of your catch can? Good idea mine just leaks on the ground[img]i/expressions/face-icon-small-blush.gif[/img]
Old Mar 8, 2006 | 01:00 PM
ERBEDS650's Avatar
I just looped a Heater hose from the breather outlet around the motor and have it mounted with a K/N breather filter under the gas tank near the Carb. Had no troubles.
Old Mar 8, 2006 | 05:49 PM
albabomb's Avatar
Thanks alot guys, just wanted to know that it was normal.............so I guess it would always be smart to check the oil before starting which by the way is a little confusing. Do you check the dipstick screwed in or out?? I tend to just pour 4 quarts in anyway since it's a dry sump, but just wanted to ask the question.
Old Mar 8, 2006 | 05:57 PM
FatHolly's Avatar
I always put in a whole gallon... it puts the oil level just a bit high but I've never had any problems.. then there is a little room to leak a little out the breather and into my intake... keeps my carb lubed. LOL
Old Mar 8, 2006 | 08:59 PM
Hightower's Avatar
the crankcase breather is very low on the DS, most come out the top of the carnkcase...silly design.
I used to have mine tapped into the intake boot too, sometimes on a very steep incline, or in the case of a rollover, a gulp of oil ends up dripping off the air filter into the airbox, kept a paper towl in there just for that.
ultimately I ended up routing a longer breather hose straight up the frame by the fan mounts, looped at top, then back down to just under frame. any gulps can fall to ground with no mess on the bike. some call it poluting, I call it returning it from where it came.
Old Mar 8, 2006 | 10:43 PM
DuneRider650's Avatar
I ride a little here and there......
Yea its normal.... i put mind under the tank where the snorkles for the airbox used to go...i also put a little k&n filter on it.
shimanok2
Jan 29, 2016 07:37 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
