chain question
I know how to tighten my chain my question is how tight is too tight. I noticed some of what i think is premature wear on the rear sprocket. How long should the rear sprocket last, hours, moderate trail riding? How tight is too tight.
Thanks
Chiknhawk
Thanks
Chiknhawk
To loosen or tighten the chain you must loosen the two bolts on the rear of the swingarm and place a screwdriver in the hole in the the rear sprocket mount through to the bearing carrier then pull and turn to make the oval (bearing carrier) move closer or further (loosening or tightening the chain).
DeFox500
Aug 14, 2015 05:59 PM
