Oh man...need electrical help
Old Mar 29, 2006 | 09:18 PM
kehale's Avatar
Default Oh man...need electrical help
2003 DS 650
main fuse has been blowing for a year (never could find the short)
Recently discovered that it will only blow at high rpm, hill climbs etc.
I can't make it do it at any rpm below 5500.
I've done all the tricks to try to find the short (Short of foil on the fuse [img]i/expressions/face-icon-small-wink.gif[/img] ) , and have pretty much ruled out a wire causing the problem.
Could it be a charging problem? e.g. regulator? or maybe a spark plug coil shorting?
I don't know much about this stuff.
Any ideas?
Old Mar 29, 2006 | 11:14 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
The fuse holder more than likely sucks a nad(IN english is worn out) the spades sockets heating up and cooling down create a poor connection and when you demand max power she arc's inside and the fuse blows.just recrimping it will not necesarily do the job they are cheap replace it i alway put automatic circute breakers in mine.LIFES GOOD THEN.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 30, 2006 | 01:40 AM
DuneMe's Avatar
AZ saw this happen on my bike after having it occur on his bike. Not common but, it occurs.
Old Mar 30, 2006 | 01:47 AM
kehale's Avatar
I'll change out the connector. Looks like an easy job.
I hope that's it!
Also, can I just put in one of those spade type automotive circuit breakers in there? Is that what you mean?
(after changing the female part of the connector, of course)
-T
Old Mar 30, 2006 | 12:40 PM
DuneMe's Avatar
AZ replaced his with an automatic re-setting circuit breaker. It is rated for the same amps but, if it trips it will lock-out for a couple minutes then reset and you'll be good to go. Don't need to keep an extra fuse with you.
I'ld think Radio Shack or an Auto parts store would have this.
I just took a small screw driver and bent the tabs out a bit. That is a lot easier and quicker. BUT . . . I'm sure I'll have the problem again and I do keep an extra fuse with me.
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
