piston install???
#21
okay so far i've only had about 30 mins to work on it, so i got the front plastics off, then took off the gas tank, this morning i only was able to get the cover off where the cams sit. i've been checking clearances and such, and i cant really see where i would need to notch the frame to get the head off, i figure i'll take the intake off and it should pop right off, can anyone direct me to where i need to notch the frame because i cant see where i would have to.
#22
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Resident Killer!
check eaglecollectors site He has detailed photos of pretty much every detail. You should be able to find your answers there. =]
Eaglecollectors site
#23
Update, i finally got it done. wow it took probably a full 8 hours of working to get her done. ran into some problems with the top intake bolt, nasty little bugger, headers were a pain to get on. notched the frame, we mostly just took our time to make sure everything went together smoothly. i fired her up tonight to make sure it ran, took it for a quick spin down the road to make sure there were no leaks, and no funny sounds and such, it ran great. i never cracked her down or anything, im gonna wait till tomorrow to fully break her in :-)
#25
this is kind of a dumb question but would the higher compression piston require some carb adjustments?
#26
okay she was running perfect today, actually got to drive it for about 30mins. i ran low on gas and i had to go home with it (3 miles) so only thing i could do was put about 1/4 gallon of 87 in it. i know it was not a wise decision but i need to know if that is whats causing my problem. so i put that little 87 in there and get going down the road, and 2 miles down the road it bogs like no other. so i downshift and rev it up and it is good again, then it bogs and keeps bogging i was acutally scared it was locking up, but i got it home and checked the oil, it was full but seemed like heat was coming out of there or smoke. whats the problem?
exmotocrosser
Sep 13, 2019 06:12 AM
jrooker6
Apr 23, 2016 07:36 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
