LEAKING OIL
Old May 23, 2006 | 04:58 PM
BioWare's Avatar
Toxic Ryder
Default LEAKING OIL
The ds650 has been leaking some oil, I can see it on the skid plate. I'm guessing that it is coming for the drain plug. But not sure if that is the problem. Is there a way to check to where the leak is comming from...any input helpful.
Old May 23, 2006 | 07:00 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Default LEAKING OIL
Clean the motor and degrease everything with carb cleaner until bone dry run it and treat it like a fat chick. Check for wet spot[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 23, 2006 | 07:02 PM
BioWare's Avatar
Toxic Ryder
Default LEAKING OIL
Thanks for the tip I'll try it. I like fat chicks..
Old May 25, 2006 | 08:46 PM
maxxedouty's Avatar
Default LEAKING OIL
Does the drain plug have a gasket, and if so do they reccommend for it to be reused?
Old May 26, 2006 | 01:25 AM
FatHolly's Avatar
Default LEAKING OIL
No gasket... just a washer. Are your threads ok? It should seat flat and seal.
Old May 26, 2006 | 01:01 PM
maxxedouty's Avatar
Default LEAKING OIL
I need to make a correction when i said gasket, i should have said washer. my manual says not to use the washer again,its says caution. 06 outty 800
Old May 27, 2006 | 02:00 PM
DuneRider650's Avatar
I ride a little here and there......
Default LEAKING OIL
I was leaking oil from around the sprocket and that created a mess everywhere. Another place i was leaking oil is up near the starter...its just a dribble here and there and not enough to even barely notice. My skids were always oily and greasy 24/7 when my sprocket seal was gone...changed it out and they havent been oily since.
Old May 27, 2006 | 08:18 PM
Steveo10's Avatar
Default LEAKING OIL
Check under the housin on the rite side of the bike... i must've hit a rock or something. I was leakin from there.
Old May 28, 2006 | 12:53 PM
FatHolly's Avatar
Default LEAKING OIL
DuneRider, I had a problem with an oil leak at my starter as well... it was making a huge mess... the problem is the o-ring that seals the starter in the case. Mine was worn and melted a little... I think what happened was I had been lean on a very hot day. Since the head pipe is so close I think it flattened out, then the vibration took care of the rest. It was an easy fix... even though I ordered the OEM replacement from Bomb ($12 for an o-ring [img]i/expressions/face-icon-small-disgusted.gif[/img] ) I didn't end up using it. I went to the hardware store and got one that was thicker than stock... if I remember correctly it was a #19???? Anyway, it only cost me 50 cents at the local Ace, and I have not had a leak since.
Old May 28, 2006 | 04:15 PM
Default LEAKING OIL
Thanks, ill take a look at that.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
