timing chain
Old Jun 10, 2006 | 12:36 AM
MAXBOMER's Avatar
Default timing chain
just instaled piston 11.5.1 je everything went smoth until cam chain it to tight , like its jamed on crank sprocket i had marked chain with a marker and iam not even close to line up cam markes with chain markes.
Old Jun 10, 2006 | 01:00 AM
FatHolly's Avatar
Were you locked at TDC? As long as you were you just need to position the cams with the lobes away from each other.
Old Jun 10, 2006 | 02:06 AM
MAXBOMER's Avatar
just goter done i did have piston tdc just got markes lined up went together pretty easy after that will fire up maybe on sunday, checked valve clearence 3 were at 005,one had only003 will ajust valves later this fall.
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
Sjrpp
Jul 5, 2015 09:04 PM
