bogging out
Old Jul 25, 2006 | 03:41 PM
onastick's Avatar
Default bogging out
[img]i/expressions/face-icon-small-confused.gif[/img]
I have a 2004 outlander max xt.
sometime while driving I open up the throttle and after a sec it seems to bog out a little.
the top speed was 100+ now 90-/+.
I cleaned the carb and filter and new plug.The belt is good and cleaned the tank.
Is there any thing else I could try?
thanks
Old Jul 25, 2006 | 04:24 PM
bombrider04's Avatar
Default bogging out
the 04 does it have a carb or fuel injection becuase if it has a carb try cleaning it out and then try cleaning the petcock. Or adjust the idle or the float on the carb.
Old Jul 25, 2006 | 04:30 PM
onastick's Avatar
Default bogging out
It does have a carb and I already cleaned it.
Sorry but what is a petcock?
How can i adjust the float?
Thanks for the reply.
Old Jul 25, 2006 | 04:57 PM
Default bogging out
the petcock is where you turn the gas on and off its called a fuel petcock and just take it off and make sure its not clogged with anything. The float is on the bottom side of the carb which lets the gas flow in the carb there should be an adjuster becuase the carb might not be getting enough fuel. Also have you tried turning the idle screw. I totally forgot to add this which is most likely the problem take the top part of the carb off and check the diapragm of the carb if it is torn or ripped them this is the problem if im not mistaken it should be like a black rubber that connect to where the needle is and there is a black plastic attached (thats how it is on my ds650) check the whole thing over and make sure it seals right when putting it back together(also make sure there aren't scratches on the black plastic part if so lube it with wd40 or something)
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
