Axle Help Needed Fast!!
Old Aug 23, 2006 | 10:32 PM
DuneRider650's Avatar
I ride a little here and there......
Default Axle Help Needed Fast!!
Sorry...no i havent figured it out yet but i do no that some ppl have done this but they dont seem to be jumping in on the subject...ive decided to simply refund my money on my axle and order from a diff distributor for cheaper. I emailed durablue also and there is only 2 versions of axles for the ds...the 2000-2003 and 2004-2006 just like i thought at first...so i got the 00-03 axle which dennis kirk says is the 04-06. What i do no for sure is that the old sprocket hubs are shorter than the new sprocket hubs and well thats pretty much all ive figured out yet.
Old Aug 23, 2006 | 11:40 PM
cloftis's Avatar
well maybe you could answer this the ring thats inside the splin, would it hurt to file down?to get over the lip of the axle so i could slide it on the axle to were it belongs?
Old Aug 24, 2006 | 01:13 AM
cloftis's Avatar
question has anyone changed brake hub from a 2001 to a 2002, or a 2003 to a 2004, or a 2005 to a 2006 and what mods were made?? just looking for some TLC????
Old Aug 24, 2006 | 08:58 PM
Well im not to sure on this subject so i dont no it that would be good or bad....guess we are the onlyones that have run into trouble...im doing to call dennis kirk tommorow and try and figure it out with them.
Old Aug 25, 2006 | 11:55 AM
  #15
flyinscrammy's Avatar
I went through the Duracrap circle two months ago. THey actually sent me the wrong axle 3 times! THREE FREAKIN TIMES!!!!!!! The second wrong axle, which was the same exact one as the first one, I used a micrometer and sent them the exact measurements of the original axle..... THey still messed it up and sent me a Preadator axle, it wouldn't even slip into the housing..... Check out the team axles, why would you have to make an axle fit??? Why would you have to look for other sprockets????? JUst my $.02 about Duracrap axles......
Old Aug 25, 2006 | 06:26 PM
  #16
K well finaly figured this entire thing out...just got off the phone with a guy at Dennis Kirk. I forwarded him the email durablue had sent me saying there are only two axles made by them for the ds650 the 2000-2003 and 2004-2006 models. What a person from Durablue said was that i would have to machine both hubs in order to use the older axle on my 04 model. Dennis Kirk is sending me the right durablue axle now...we did measurements of the spline over the phone so there shouldnt be any mix up this time. Dennis kirk did kind of mess up on the axle shipment...but they have some of the best customer service i have ever recieved.
Old Aug 25, 2006 | 08:20 PM
  #17
Entomber's Avatar
I'm fitting a 00 with a an 04 Swingarm (many reasons why I am doing this in case anyone scratches thier head). I was considering a durablue axle to put on my bike but... I want the 00 width. Anything to look out for Dunerider or I'm better off haning on to my 00 Axle instead?
Old Aug 25, 2006 | 09:43 PM
  #18
i think you will be fine if you get the 00-03 model durablue axle and use all your old hubs and stuff.
Old Aug 25, 2006 | 11:41 PM
  #19
Entomber's Avatar
Just a quick question.. what model of axle from Durablue are you guys using? I assume stock DS hubs fit on these axles. What about the lock nut? Wear rings? etc...
Old Aug 26, 2006 | 08:44 PM
  #20
cloftis's Avatar
I beleive my axle nightmare is over!!! talked with missionmotorsports this morning very helpful!!! with my research and theirs we came to the conclusion i had the 04 and newer durablue axle with billet sprocket hub!! Sent it back to them this morning, they will send it to durablue, scheduled to get new one back next week!! if anyone is on west coast and dealing with horrible customer service , I highly recommend these guys ask for Larry!! Normally when you buy something off of ebay its your problem not sellers! these guys have been very helpful and will do more business with them in future!! its unbeleivable that the two of us had the wrong axles, both oppisite of each other, will keep you posted on the new one when it arrives. thank you for your help dunerider with the two of us and our problems hopefully we will both be able to move on!! carlton
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
yagerzzz
Jun 24, 2015 07:45 AM
rcappie4
Jun 7, 2015 02:53 PM
hoopduerr
Jun 1, 2015 08:22 PM
