tach not working...
Hey guys...i am working on putting my ds back together....still! I just haven't had much time to do it.
any clues as to why the fact. tach. isn't working on my DS? It just doesn't do anything. I have cleaned up all the wiring and made sure everything was connected good. The only problem I have seen is the grey nut that connect the wires to the back of the tach. will not tighten. But the wires inside still appear to be attached. I dunno....
Any replies to either question are greatly appriciated!
there are two cylinders just above the rad. that it hooks into in some strange way. The tach, the key, lights and all the electric up front are all wired through each other in one way or the other. some just have other wires that go back into the main harness. The problem with that therory is that when one of those fuses blows i loose just about everything. Right now the only things that don't work are the tach. and I forgot to mention the kill button (don't have a tether yet.). It doesn't do anything either. Everything else up front works...lights, dash lights, key, start button, everything! If someone knows about a hidden fuse please do tell!
Thanks again!
Thanks again!
Logan Collins
09-05-2015 08:03 PM
cody500ho
14
08-14-2015 05:03 PM
