Home built air shifter
Old Apr 4, 2007 | 04:34 PM
tom18801's Avatar
Default Home built air shifter
Im putting together an air shifter for my 2000 DS so far i have several air/electric solenoids that are 24 volt dozens of shapes and size air cylinder and a bunch of air line i plan on machining an adapter to connect an argon or oxygen regulator to a paintball c02 tank so i can get down to around 120 psi my plan is to have a handle bar mounted upshift button or to make the clutch pull safety swith activate the shifter. any input
Old Apr 4, 2007 | 06:18 PM
DuneRider650's Avatar
I ride a little here and there......
120psi holy crap thats enough to rip the shifter clean off lol. Unless your planning on having it so the stroke is completely maxed out where the linkage ends.
Old Apr 4, 2007 | 08:03 PM
Hightower's Avatar
radius of cylinder piston squared X 3.14159 X psi = force
if you are using a tiny cylinder lilke 1/2" in diameter at 120psi that's about 23 pounds force, I think a miniature cylinder around this size would be convenient and trick.
not sure how much force is needed for shifting but I know there's somebody on here with an air shifter that can comment I think? I think maybe THEBOM has some insight
Old Apr 5, 2007 | 02:49 PM
tom18801's Avatar
Hey thats a cool formula and i do have cylinders ranging from 5/16 to 5/8 and i plan on using a spring to pull the shifter so if something dosnt want to go it wont bend a fork
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
dannytas
Sep 26, 2017 06:31 PM
EIF
Apr 20, 2017 07:15 PM
CosmoM
Sep 21, 2015 04:57 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
