she's home.... now what?
<div class="FTQUOTE"><begin quote>Originally posted by: crazy1291
kk, valve adjustments are important i see..... how much does it cost? it involves a bit more work than on a standard quad, as you also have to remove the cvt cover and some other stuff
edit: will they have to replace the gearbox oil if they take off the cvt cover? will it come spilling out?</end quote></div>
Should be about 150 at most bike shops, as long as its nothing more than a re-shim. If your valves have worn too far because they got too tight you may have head damage, but I think you said you DS was only a few months old maybe??? If its that young you have nothing to worry about. If its an older DS that has never been adjusted you may have some issues.
<div class="FTQUOTE"><begin quote>Originally posted by: FatHolly
Should be about 150 at most bike shops, as long as its nothing more than a re-shim. If your valves have worn too far because they got too tight you may have head damage, but I think you said you DS was only a few months old maybe??? If its that young you have nothing to worry about. If its an older DS that has never been adjusted you may have some issues.</end quote></div>
150 for a valve adjustment, I dont know where you are from but if I were you Id buy the tools and do it myself before I paid that
#15
my sons new DS250 ran like crap just like yours till I put a dynojet kit in. Factory jetting on the DS is BS now it starts no choke everytime idles smooth, great pick up . I do all my own service and valves on the DS were real easy to do but after 30hrs of trail and track riding they were dead on 4 thou called the dealer to double check he said thats good thats typical of these DS motors. I would try what bombrider04 said, clean carb real good put in a new plug. My sons Ds runs flawless yours will to
Johnnyairtime
Dunes and Dune Machines
10
04-03-2005 04:14 PM
