ds650 won't run
Old Dec 16, 2007 | 10:59 PM
ericpcars's Avatar
Default ds650 won't run
I thought it was the battery so I bought a new one,And it ran fine for one day. The next weekend the battery was dead.I jump started it and it will only run with the cables attached,It will not idle unless the cables are hooked up.I can't test the stator with the cables hooked up but won't run without.What could be the problem??
Old Dec 18, 2007 | 12:50 AM
cynick's Avatar
It needs a rectifier, I had this same thing happen to me a while back, except it cost me 3 batteries before I figured it out. It is located under your airbox, and power will go into it but none will come out or too much will come out and fry the battery. Have you installed a CDI recently? Installing a cheap one will usually fry the rectifier and battery also.
MRDS650
Feb 22, 2026 11:26 AM
ThreeWheelio
Jul 21, 2000 04:16 PM
ScoobyDFW
Jun 13, 2000 11:33 AM
KawasakiKid
May 11, 2000 03:42 AM
ScoobyDFW
Apr 10, 2000 06:52 PM
