backfiring ds 650
Old Dec 25, 2007 | 03:29 AM
DSNUT's Avatar
Default backfiring ds 650
Check all your grounds to....
Old Dec 26, 2007 | 07:21 PM
FDLdsrider01's Avatar
Well went thru grouns and B+ cables cleaned everything. Load tested the battery and it was bad, but it was 3yrs old, it was an oddessy. So I bought a new oddessy battery started right up and ran perfect for a few hrs then just like that the lights dimmed, so I shut if off then tried to start and nothing battery is to dead to turn over again WTF. So now Im chaging the battery to start up ds againt to see if it is the charging system
Old Dec 27, 2007 | 01:02 PM
yammimoose's Avatar
My friend also has a DS. It came with a 9 volt battery. It would start and run ok but he kept blowing tach's
Just a thought...
-Moose
Old Dec 27, 2007 | 01:03 PM
yammimoose's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: yammimoose
Just a thought...
-Moose</end quote></div>
The double check that you have the right battery part got lost.....
-Moose
Old Dec 27, 2007 | 03:00 PM
  #15
DSNUT's Avatar
I think we are back to the rectifier. Cynick mentioned it in a previous post. If the battery isn't charging, it is rare for a stator to go bad. I would buy a new rectifier at this point and go from there.
Old Dec 27, 2007 | 09:10 PM
  #16
Thanks for the help people! I bought a shop manual tested everything and yup its the rectifier. So I already have one on order. And also I do have a Ron Woods C.D.I in the DS
Old Dec 27, 2007 | 11:56 PM
  #17
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
[img]i/expressions/beer.gif[/img] Your cdi is bad Aceisback had the same problem up at sand mountain utah battery went dead [killed it] run like hell ,drove a hundred miles for a new battery bike run good for 30 minutes, then like poop then fried the new battery some one had an old cdi and a older battery the bike run good. Get you a volt meter,disconnect the positive battery cable put the volt meter between the battery and the positive cable turn on key you will likly see amost a dead short, unplug the cdi box to see if the dead short goes away, if not unplug the voltage reg., then the stator, that it theres nothing left[img]i/expressions/musicnote.gif[/img]
Old Dec 28, 2007 | 12:36 PM
  #18
Yea when I unplug the 2wire clip from the rectifier the bike stops acting up and runs good but then I have nothing for a charging system. So its got to be the rectifier says the shop manual.
Old Dec 28, 2007 | 03:26 PM
  #19
DSNUT's Avatar
I suppose it could be either the rectifier or the CDI. Test it as Ray described and you should know.
Old Dec 28, 2007 | 07:00 PM
  #20
cynick's Avatar
That's what fried my rectifier and in the end my battery. I installed the stock cdi until I bought my Vortex and had no problem after that.
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
