looking for someone to lighten ds650 flywheel!
Old Dec 21, 2007 | 11:08 AM
TheStir's Avatar
Started riding ATVs in 1974!
Default looking for someone to lighten ds650 flywheel!
<div class="FTQUOTE"><begin quote>Originally posted by: THEBOM
WOW, How would you hold it together after cutting the end off ??? It's a pressed and sealed type unit. Looks like it would sling apart with out being re crimped???? Plus re balancing it for zero balance.</end quote></div>
No idea, I have not seen one cut that much. I'm going off a thread I started when I was looking into a lightened flywheel myself.
Old Dec 21, 2007 | 02:34 PM
BOMBSAINT's Avatar
sorry but as for internal mods i am a novice.... what is the benefit of a lightened flywheel and what are the real world results/performance gains.... fill me in and it may be in my future of its worth the coin
Old Dec 21, 2007 | 03:52 PM
cynick's Avatar
Faster rev, lighter all around mass, less rotating weight. Trust me it will totally change the power delivery in a good way.
Old Dec 21, 2007 | 06:12 PM
SANDMAN430's Avatar
anyone have a dyno of a before and after?
Old Dec 21, 2007 | 07:03 PM
  #15
goobds650's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: cynick
Faster rev, lighter all around mass, less rotating weight. Trust me it will totally change the power delivery in a good way.</end quote></div>
I've looked into this before. Quick high rpms is the good thing. The bad thing is that you lose momentum energy of the flywheel spinning, which is good for getting up hills.
So if you ride redline on level ground competitively, it may make sense. The light weight helps is get rpms quickly, and lose rpms quickly too. But the extra weight of the flywheel keeps it spinning stronger longer when you need it on a hill.
Otherwise, that $250 may be a small part of the total upgrade cost for questionable performance gains: which all depends on how you ride it. Is this an ATV site or drag site? Maybe I'm on the wrong site, and sorry if so. Whoops!
  #16
TheStir's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: SANDMAN430
anyone have a dyno of a before and after?</end quote></div>
I do not think you will see more, just faster revs...
Old Dec 21, 2007 | 08:12 PM
  #17
cynick's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: goobds650
Otherwise, that $250 may be a small part of the total upgrade cost for questionable performance gains: which all depends on how you ride it. Is this an ATV site or drag site? Maybe I'm on the wrong site, and sorry if so. Whoops!</end quote></div>
I dune mine all day long and have never had one issue. And mine didn't cost me no $250. It was one of the cheapest mods I made and I really like the way works with it on. I do drag sometimes but it is not the only thing I do we are usually out dunin.
Old Dec 21, 2007 | 10:56 PM
  #18
BigWaynester's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: flux
give eric a call(mr horsepower) 270 334 3331....
its like 250.00 and he takes about 2.5 lbs. off....
thats about all you can safely remove....</end quote></div>
2.5 pounds is A LOT , I forgot what a stock one weighs.
someone should call him and verify.
Old Dec 22, 2007 | 12:40 PM
  #19
flux's Avatar
on the on-dunes forums someone checked one , eric cut it and then he rechecked it... it lost around 2.5 lbs.... as far as lossing( lugging power) the ds flywheel has
mass to spare, its heavy..... if i could find a aftermarket(lighter yet) flywheel
i would buy one.....
Old Dec 22, 2007 | 02:05 PM
  #20
mystereid's Avatar
It's official, I've been duning for over 30 years.
I have a spare from a BMW f650, complete with hub attached. It weighs slightly more than 5 lbs, scientifically determined by lifting up on it slightly. ( My postage scale only reads to 5lbs ).
Team Pami used to have picks on their website of the lightened hub.
