fried cdi
Old Dec 21, 2007 | 10:31 PM
ericpcars's Avatar
Default fried cdi
while trying to diagnose the problem of why my ds would only run with jumper cables installed I decided to try another cdi. I installed the cdi and started it up and it idled fine like with the factory one.So I removed the cables and it still ran fine(I smiled).Then I hit the throttle and it suddenly shut off.I reinstalled the cables and it would not start just spin over,then I smelled smoke and saw the cdi bellowing smoke.I immediately unhooked it,(toast)then I plugged the factory one back up and It will only spin but not start! Can someone please help!I have a rectifier on the way,would it cause that because I do not want to fry my ron wood cdi thats on the way too!
Old Dec 21, 2007 | 10:35 PM
SANDMAN430's Avatar
Default fried cdi
call the bom or gary or eric those are the engine guys and have the answer for you.
Old Dec 21, 2007 | 10:46 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Default fried cdi
Bad ground and you pumped too many amps at her and she found a ground in the ing. But it was too small for the amperage draw and smash that will smoke up a garage won't it[img]i/expressions/face-icon-small-disgusted.gif[/img] i have watched a mechanic of mine do the same thing just before he went on unemployment...[img]i/expressions/face-icon-small-wink.gif[/img] did you end up with a hole burnt in her.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Dec 24, 2007 | 02:18 AM
cynick's Avatar
Default fried cdi
I would think your rectifier is junk, install stock cdi and new rectifier when it arrives before installing the RW cdi.
skittero
35
Mar 1, 2019 12:39 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
JoeB
Mar 4, 2002 08:59 AM
ERICsRAPTOR
Feb 25, 2001 11:29 AM
