TM48 VS LECTRON 48
Old Jan 14, 2008 | 11:30 PM
DSNUT's Avatar
Default TM48 VS LECTRON 48
Why in the world would you need 14 filters on only two tubes?
Old Jan 14, 2008 | 11:38 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
14 Divided 2=7 fresh filters for each day of they week.....[img]i/expressions/face-icon-small-happy.gif[/img] No i meant 14".
Old Jan 14, 2008 | 11:51 PM
DSNUT's Avatar
AHHH! I see! [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 15, 2008 | 12:03 AM
busmechanic's Avatar
just wondering if the lectron still comes with the billet moose throttle? the adjustable fitting that came in mine did not work right. the cable sawed the fitting on the sides. after a few rides the cable started binding in the grooves that it created. I am sure they have addressed the issues by now?
Old Jan 15, 2008 | 01:25 AM
  #15
SANDMAN430's Avatar
the stiff spring on the tm is old news they have different springs now plus the choice of cable is a big thing but i hear it is the same for the lectron, tuned right the tm is great, but tuned right aren't most carbs, and tuned wrong they suck. The lectrons have had some kind of deal where the slide sticks from vacuum, there might be a simple fix for this, but most issues can be fixed either carb. like azsand said the fcr is a good carb, but if you are going to see the bomb he has all kinds of info on these, for the problems you might hear. the shop i work with in my town sells fcr for there builds, said something about beer can and lectron, but a ok drag carb was there answer. but then there tech person is a girl
Old Jan 15, 2008 | 01:36 AM
  #16
Sandragggen's Avatar
I like to see a test like Jeff and Eric did a few years ago with the TM45 and Lectron46, but this time with dual 39FCR's and dual 38 Lectron's. AZ you were there. Have each guy tune until he say's that's it on his prefered carb. I'd throw in a couple of hundred to find out which set of carb's has the best usable power. This might make for a good reality atv show.....hmmmm. Anyway.
Old Jan 15, 2008 | 02:01 AM
  #17
SANDMAN430's Avatar
i think the guys with the dynos can tune the products they have well, but for a shoot out that might be a hard rematch.
Old Jan 15, 2008 | 09:28 AM
  #18
CALDS650's Avatar
I went with the TM the lectron will not work with the IMS gas tank with major re shaping of the tank which I due not like
Old Jan 15, 2008 | 12:55 PM
  #19
DSengineer's Avatar
Has been here a long time!
<div class="FTQUOTE"><begin quote>Originally posted by: CALDS650
I went with the TM the lectron will not work with the IMS gas tank with major re shaping of the tank which I due not like</end quote></div>
Eric sells a 90* cable that should work fine with the IMS.
Old Jan 15, 2008 | 03:36 PM
  #20
pipelayer's Avatar
I'm a Plumbing contractor and I have some old friends that always called me Pipelayer for some reason?
remember Nutjob, azsand said 14" that is really 4"
