Quick Oil Change
Old Jan 31, 2008 | 05:46 PM
BioWare's Avatar
Toxic Ryder
Default Quick Oil Change
I have done some fast oil changes in my time, But now that I think about it. If you do not drain the oil resivor, how much oil do you new to top it off with.
Old Feb 1, 2008 | 08:39 AM
DS650powe's Avatar
Runs a 730 kit from OMW with web109's and a 48mm lectron. It has some serious torque!
atleast 2, i did this a few times.
Old Feb 1, 2008 | 10:01 AM
BioWare's Avatar
Toxic Ryder
quarts thats cool, so their is about 1/2 quart in the oil resivoir.
Thanks
Old Feb 3, 2008 | 04:36 PM
DSengineer's Avatar
Has been here a long time!
Total oil capacity on the DS is just over 3qt. The motor holds about 1qt and the tank holds about 2 qt. If your changing oil do both.
Old Feb 4, 2008 | 01:04 AM
DS650powe's Avatar
i always can fit 4 in mine...and it shows up on the dipstick perfectly??
Old Feb 4, 2008 | 01:51 PM
1882's Avatar
Runs a Full 730 Race Build!
Yes, 4 quarts is the correct amount.
Old Feb 4, 2008 | 02:51 PM
BioWare's Avatar
Toxic Ryder
Thanks for the info guys
Old Feb 4, 2008 | 05:12 PM
DSengineer's Avatar
Official capacity from BRP is 3.3qt and that is about max what I can put in both my 04's. I have never been able to get a full 4 quarts in. Be carful not to overfill!
factory specs
Old Feb 4, 2008 | 11:56 PM
1882's Avatar
Well, I should add that when I change my oil after draining the engine along with the remote tank I take the air compressor and blow through the tank filling the gaps around the compressor nozzlle with a shop towell to get a good seal and a good amount comes out of the engine through the drain plug. Doing this demands a full 4 quarts if not a slight bit more. A traditional oil change would more likely only need 3.5 give or take...
Old Feb 5, 2008 | 12:33 AM
busmechanic's Avatar
I allways drain the line from tank that goes under the rad. where it sags by removing it. essentially the same thing as blowing it through with air. I generally have a half quart or a little less left from a gallon jug. never needed a full gallon to fill.
