DO I need a TM45????
Old Feb 2, 2008 | 02:34 AM
1FastDS650's Avatar
Default DO I need a TM45????
Ok so I had a Ron Woods High comp. piston added and the head Port and Polished. I have taken my jetting up to a 200 right now and it acts like its still running lean.... I ordered a new set of snorkel tubes and the boots that connect them to the air box. I lost the other set somewhere and I just had some rags stuffed in the holes to reduce airflow but just didn't want to run right. Do you think I need to get a TM45 carb for this to run right???
Old Feb 2, 2008 | 02:50 AM
NickDS650's Avatar
I dont think u need to run a bigger carb to help it run better, but i do think that a diff carb would help go with all the upgrades, the 45 or the 44 or 46, the dual carbs, or even EFI
Old Feb 2, 2008 | 10:55 AM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
I usually tell people to get either a TM 45 or TM48 before you even put cams or pistons in. The stock carb is killing your power. It needs much more air!!!
Old Feb 2, 2008 | 04:38 PM
1FastDS650's Avatar
Where is the cheapest place to get a TM45?
Old Feb 2, 2008 | 06:30 PM
DuneRider650's Avatar
I ride a little here and there......
Prob off ebay...or you could go the way im going and just get EFI and never have to worry about it again.
Old Feb 2, 2008 | 06:33 PM
cynick's Avatar
Also check the garage thread.
Old Feb 2, 2008 | 08:39 PM
Hightower's Avatar
for uncompromised service and proper setup THEBOM can't be beat for buying a new one.
Old Feb 2, 2008 | 11:28 PM
TheStir's Avatar
Started riding ATVs in 1974!
I love my TM 45, matter of fact I would not trade it stright across for fuel injection it works so well and has been so simple to tune an reliable.
Hightower is right about THEBOM, he has been a great help to setting up my DS, but Hightower is being modest as he got me dialed in so close with my TM 45 that I only had to mess with my main 1 size...
Old Feb 3, 2008 | 12:07 AM
1FastDS650's Avatar
Well I just bought one from someone on here from ebay. Got a good deal on it 185 shipped.
Old Feb 3, 2008 | 12:31 AM
TheStir's Avatar
If its not a RW TM 45, get the extended neck for the intake side for it from RW or THEBOM
