ds650 stock cylinder
HEY guys.
any of you guys have a spare stock cylinder they would part with in good shape.
im looking for one that just needs a hone (not boring out and re-nokasil)
let me know thanks.
let me know thanks.
it worked great. and it still works great. but with a little oily smoke. the thing is i got everything together went for the first trip of the year and the nut popped of of the head stud. i found out that you should never reuse thos nuts they are designed to be used once the threads came completely out of the nut (looks like a bushing). after that i replaced the nuts, new head gasket and slapped it back together.
i found out that the coolant that found its way to the cylinder warped the steel sleeve. runs great but oils getting into the combustion chamber. Guys always replace thos nuts its like 2 bucks a lowes. SO now istead of replacing the sleeve for 120 bucks and paying someone to press the old one out and push the new one in and also resurface the deck with the cylinder. $$$ its cheaper for me to go back to stock bore with a high compression piston. and thanks for the help i got one on e-bay.
