Oil Pressure Switch
Old Jul 15, 2008 | 01:37 PM
Swaie's Avatar
Default Oil Pressure Switch
Okay here is the deal, either my oil pressure switch is bad or my bulb is blown. It doesn't come on when I turn on the key. Where do I get a replacement bulb for the dash.?Can you get a oil pressure switch from somewhere like Autozone or something like that?
Old Jul 15, 2008 | 02:03 PM
jusrlax's Avatar
I have never heard of the bulb blowing out, but I guess it could happen. You need to get an OEM oil pressure switch. They cost about $15. You could always install an actual gauge if you wanted, others have done this. If you run with none of the above, you won't know there's a problem until its too late.
Old Jul 15, 2008 | 02:10 PM
FatHolly's Avatar
I would put money on it that its the oil pressure sensor. If they get wet (like from washing after a ride) its done, and it is VERY common. Most of the old school DS guys carry a couple in their tool box because of this. Replace the sensor.
Old Jul 15, 2008 | 03:40 PM
Swaie's Avatar
The closes Bomb dealer is about 75 miles away. Is there any alternative place to get the sensor like Autozone, or NAPA ?
Old Jul 15, 2008 | 03:43 PM
jusrlax's Avatar
I am pretty sure the switches are specific to the Rotax 650 motor. If you don't want to go the dealer, bikebandit.com has the microfiches you need to order online.
mtdewmn
Jan 19, 2017 12:13 PM
fordfaithful21
Dec 7, 2015 05:52 PM
toonces
Sep 5, 2015 01:14 PM
Stirling
Aug 9, 2015 01:49 PM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
