Brand oil & weights for DS-650?
Old Feb 6, 2009 | 06:40 PM
brian 68's Avatar
Default Brand oil & weights for DS-650?
ds 650 manual lists 10 w 40 , sj, or sh, mineral based oil, any motor oil that uses these letters is made for wet clutches, also make sure the circle does not say ' energy conservitive' just to be safe. i have run valvoline or castro 10w 40w sj or sh, for over 7 years in mine and it looks new inside, i catch it on sale for 11 to 12 $ per gallon .
Old Feb 7, 2009 | 06:32 AM
learnem's Avatar
cool thanks. i was reading that energy conservative thing on thumpertalk yesterday..... i picked up a gallon of or that rotella yesterday for 11 dollars
Old Feb 9, 2009 | 02:27 PM
ERBEDS650's Avatar
Kendall 10/40 or just 40 weight I get it at pep boys, I figure the oil gets changed way before it will ever break down, any wet cluch is going to leave deposits / dirty the oil , I change it and the filter every other trip.
Old Feb 9, 2009 | 10:48 PM
McKay5858's Avatar
I use whatever synthetic 10w40 happens to be on the shelf that day. I also have the scotts reusable filter, really like that.
Old Feb 10, 2009 | 10:20 AM
  #15
brian 68's Avatar
hay mckay didn't you get new cam's. both set of web cams ,[ regrinds] i bot a set in 01 and last week. web recommends not using synthetics or semi synthetic
i read befor that it causes the lobes to wear prematurely . the manual also says mineral based oil only, i'm sure some might be aright, but why take the chance.
i'm, with erbe i change the oil every couple rides. the clutch is the weak link on a modifyed ds so contamination is more important than long oil life. i think alot of people will put off changing the oil if it is expensive. [stating that is why i use the good stuf] . i'm not trying to start a oil war , but newer motors are designed for synthetic's old design's were not , i have also heard that some seals dont like some synthetics, and so on.
wendal
Sep 7, 2019 06:46 AM
EIF
Apr 20, 2017 07:15 PM
Robinhood
Dec 26, 2015 10:28 AM
fredrikrosen
Sep 28, 2015 09:58 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
