sprockets?
Old Dec 3, 2008 | 11:20 AM
SilverBomb's Avatar
SilverBomb has got an Addiction!
Default sprockets?
True that, there is not a 400 that should keep up to a stock DS.
Old Dec 3, 2008 | 09:54 PM
everlast's Avatar
Default sprockets?
Thats wat I thought mabye I should put the stock jets back in. Those rear tires I bought are pretty heavy could that have that much to do with it?
Old Dec 3, 2008 | 11:22 PM
everlast's Avatar
Default sprockets?
does anyone know how to shrink their icon it keeps saying tempstruck undefined.
Old Dec 4, 2008 | 02:17 AM
SilverBomb's Avatar
Default sprockets?
Whoah!! that's one big avatar!! LOL!
Old Dec 22, 2008 | 10:09 PM
  #15
everlast's Avatar
Default sprockets?
Thanks I put a 15 tooth sprocket and re jetted to a 180 dynojet I crushed everbody that had beat me before and put them back to the drawing board. Whats my next step for speed?
Old Dec 23, 2008 | 01:12 AM
  #16
SilverBomb's Avatar
Default sprockets?
Nice Man!! Next Step, bigger and better carb.
Old Mar 3, 2009 | 05:26 PM
  #17
jfar's Avatar
Default sprockets?
great info on this thread. I have been looking for some more top end speed to my DS. I put a K&N filter on and a power tip. I am into long desert races (i am signed up for the Vegas to Reno 1000 miler in August with two other teammates) and really want an all around performer for the quad. My DS can take a beating and keep going but I would have thought I'd get 75+ MPH top end at least. With the throttle pegged, I am getting 66 (on a flat surface) both on my speedometer and on a GPS device that is really accurate. Am I crazy that my DS should go much faster? Would a different sprocket work for this or would it just get me from 0 to 60 faster? thanks!
Old Mar 3, 2009 | 05:35 PM
  #18
SilverBomb's Avatar
Default sprockets?
<div class="FTQUOTE"><begin quote>Originally posted by: jfar
great info on this thread. I have been looking for some more top end speed to my DS. I put a K&N filter on and a power tip. I am into long desert races (i am signed up for the Vegas to Reno 1000 miler in August with two other teammates) and really want an all around performer for the quad. My DS can take a beating and keep going but I would have thought I'd get 75+ MPH top end at least. With the throttle pegged, I am getting 66 (on a flat surface) both on my speedometer and on a GPS device that is really accurate. Am I crazy that my DS should go much faster? Would a different sprocket work for this or would it just get me from 0 to 60 faster? thanks!</end quote></div>
You should be much faster than that. One thing you need is a CDI box, which not only increases your RPM limit but adds a couple or so HP. Even at stock you should be into the upper 70's for top speed. I'm thinking you might already have a smaller than stock front sprocket also causing your slower speed. So CDI and make sure you have a 16t front sprocket and that should put you well into the 70's if not more.
Old Mar 3, 2009 | 05:44 PM
  #19
jfar's Avatar
Default sprockets?
Oops, forgot to mention the CDI box. I just checked my sprocket and it's at 16 on the front and 40 on the rear. Stock, right?
Old Mar 3, 2009 | 05:57 PM
  #20
SilverBomb's Avatar
Default sprockets?
Double post edit.
