ds 650 problem.
Old Feb 21, 2009 | 02:18 PM
foxracer1840's Avatar
Default ds 650 problem.
i have a 02 DS 650 and it wont start. its cold here, normally anywhere from 10 to 30 degrees. i pulled off the carb. and its clean and it has a a different main jet in it from dyno jet. its a 175. it gets good spark. and the battery is brand new but i drained it quite a bit when i tried starting it yesterday so i put a battery charger on it. so now i am stumped. any ideas?? thanks a lot.
Old Feb 21, 2009 | 06:07 PM
yellowdemon23's Avatar
3 things to start. Spark, Gas, Air flow. Just my 2 cents. If your getting a good spark, I would check to see if it's getting gas. if it is I would check to see if your air tube/filter is clear/clean. If all three are present then it may be something like timing, or make sure you have it in the run position on the handlebars.
Old Feb 21, 2009 | 10:24 PM
thanks yellowdemon23 i will check into the air tube and filter because i havent looked at it in awhile.
Old Feb 23, 2009 | 07:32 PM
Sport400inOH's Avatar
Adjust your air screw while you are at it - it makes a big difference in the cold, especially when the engine is cold too. Somewhere between 2 and 3 turns from gently seated will be just right - start adjusting at 2 1/4 turns and tune from there - giving a little test ride in between to clear things out.
Beeline08
Nov 11, 2016 04:00 PM
shimanok2
Jan 29, 2016 07:37 PM
JDawg8309
1) Engine problems..
Sep 12, 2015 02:24 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
black798
Sep 9, 2015 07:42 AM
