Trailing Arm Bearings
Old Mar 9, 2009 | 03:36 PM
blowedpony's Avatar
Default Trailing Arm Bearings
I went to replace my trailing arm bearing and right rear wheel bearing on my 06 800. I was wondering if anyone has cross referenced these to an auto parts store. These are the widest set of bearings I have ever seen. The Napa store here basically blew me off. I would appreciate any help. Thanks.
Old Mar 29, 2009 | 08:50 PM
BadBRP's Avatar
I,m new to this forum stuff but I have an answer to your question on bearings for rear trailing arms. My 05 400 needed new ones and when I pulled it apart there was a number on the outer race of the bearing. They were NSK bearings part #45BWD06CA93+6 look up www.ca.nsk.com search for split race wheel bearings these are the same bearings as in your cars front hubs cross reference your number on the outer race and orber a new one. Don,t go to a parts store go to an industrial supplier and you'll be golden.
Old Mar 30, 2009 | 08:42 AM
blowedpony's Avatar
the numbers on the bearings were not legible. I will give Grainger a try. Thanks
Old Apr 29, 2009 | 12:12 AM
stray's Avatar
Ball Bearings:Miniature bearing:Ceramic Bearing:Ball Bearing
you'll need the # to cross-reference, or measurements (outside dia. X inside dia. X width)
Ean
Dec 19, 2022 08:48 AM
black_thunder
Jul 28, 2015 11:05 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Peter_
Jul 18, 2015 07:06 AM
Chuck188
Jul 17, 2015 02:45 PM
