Help ds650 wont start
Old Mar 16, 2009 | 07:05 PM
justme23005's Avatar
Default Help ds650 wont start
Thats charging just fine.... glad to see it wasn't anything too expensive..
Old Mar 16, 2009 | 07:07 PM
trooper182's Avatar
lol well if you call a 125 doller battery not too expensive. only one i could find in my town. im in the army and sgt's dont make a lot lol so 125 is a lot
Old Mar 16, 2009 | 08:09 PM
That is a lot of money, but still cheaper than a stator or regulator. I run a 12bs battery in mine. Its a little smaller than the 15bs thats supposed to go in it, but they are $48 at Wal mart.
Old Mar 17, 2009 | 07:07 PM
brian 68's Avatar
i wasn't going to mention it, but since justme brought it up. i also bought a wallmart battery. but i went with a bigger battery 20 instead of 15 . it gets hard to start in the cold. it was just a little taller. got the everstart max. for 70 $. modded my batt box, to fit . works great, and easy to replace, the regular version was around 45$
Old Mar 19, 2009 | 05:29 PM
  #15
I was going to do that, but I was too lazy to modify my battery box. So far, the 12BS's have had plenty of power. One of my DS's even came with a BS9 in it. I left it in there, since it works ok. But I'll replace it as soon as it fails to start once.
Old Mar 22, 2009 | 08:50 PM
  #16
trooper182's Avatar
yea it was def the battery. i took the ds out on fri and sat for about 4 hours each day and no problems other than when i was at wide open the ds kinda hesitated/stumbled. i have a ron woods cdi and i dont think i was revving to high. never did this before but im thinking i may need to replace the o rings on my exhaust. took it off the other day to replace a gaskett. but other than that it ran like a champ.
Old Mar 23, 2009 | 10:29 AM
  #17
When mine developed a stumble at high RMP's, it was a bad diaphram in the carburetor. It was leaking vacuum, & not lifting the throttle slide like it should.
Old Apr 3, 2009 | 10:39 PM
  #18
trooper182's Avatar
yea still having issues with the atv, sigh. ok so at wide open its still cutting out. i checked the carb. pulled it all apart and dont see anything wrong with it. i changed the plugs and its still doing it. could it be a dirty filter? i just cleaned it about 3 rides ago. its a k&n. i run with no lid on the box. im at a loss and am tired of getting beat by my bro's raptor 350 because im cutting out lol. please help. tomorrow i guess i pull the filter and make a few runs to see if it clears up some.
Old Apr 4, 2009 | 06:39 AM
  #19
BBR650's Avatar
Is always changing bikes.
put the box lid back on.....the stock carb is a vaccum slide and it needs the box lid to open properly.
1000gade
May 27, 2015 12:37 PM
need4aquad
Feb 4, 2001 03:26 AM
vernl
Jan 7, 2001 08:13 PM
2punksdad
May 23, 2000 01:46 AM
hot_shoe_cv
Oct 12, 1999 08:32 PM
