Winch problems on 09 650 outlander MAX
Old Apr 3, 2009 | 11:35 AM
check's Avatar
Never make a decision before you have to, always have a Plan B, and don't tell me it's not possible!
Unhappy Winch problems on 09 650 outlander MAX
I bought a new 650 Outlander MAX XT last Fall, and it came with a 3000 lb. Warn Winch, which I used this winter to raise and lower the plow blade. The problem is, I can lower the blade no problem, but it won't come up. I have to play with it and play with it (by letting a tiny bit out and then trying the in button again), until it finally catches and brings the plow blade back up. Took it to the deal;er and he said "we fixed a loos connection", but the problems persisted when I got it home. It also SEEMS to be worse when it is colder, but I'm not really sure.
Has anyone else had this problem? (I also had problems raising the plow with my old 2004 400 Outlander MAX XT, which had the 2500 lb. warn winch, but only if the hendlebars ere turned sharply to the left.)
Any help or advice would be much appreciated - thanks!
Old Apr 3, 2009 | 05:08 PM
BBR650's Avatar
Is always changing bikes.
is your winch cable bound up ????
Old Apr 5, 2009 | 01:59 PM
yellowdemon23's Avatar
sounds like an electrical problem, or a spooling problem, just my 2 cents
Old Apr 6, 2009 | 09:26 AM
check's Avatar
I tried it again this weekend, and it seemed to work OK, but it was above freezing so that may be a reason - has anyone else had this problem?
Old Apr 7, 2009 | 09:41 AM
BBR650's Avatar
must have water in the motor.
Old Apr 7, 2009 | 10:02 AM
Sounds like a loose connection. If it was ice in the motor you'd probably hear the motor trying to turn; like a low hum. Check the connections and put dielectric grease on the connectors if you can.
Old Apr 19, 2009 | 08:59 PM
check's Avatar
Thanks, Moose. Will check the connectors and get dialectric grease. To make matters worse, the dealer on my lake no longer sells Can-Am, and so he won't work on the problem any more. So, if it isn't just a loose connection or contacts problem, I'll have to trailer it down the road a piece.
Old Dec 2, 2010 | 12:07 PM
check's Avatar
This post is a bit late, but it was an electrical problem with the connections in the winch itself - fixed under warranty.
toonces
Oct 19, 2015 02:21 AM
Gtsordo
Jul 22, 2015 01:27 PM
1000gade
Jul 16, 2015 10:48 AM
toonces
Jul 11, 2015 12:01 PM
cornermike
Jul 8, 2015 11:44 PM
