Cannot Break the Front Tire Bead!! HELP!
Old Apr 14, 2009 | 09:25 PM
justme23005's Avatar
I've had really good luck with leaving just a little bit of air in the tire, then breaking the inside bead first.... then, the outside bead.
Old Apr 14, 2009 | 10:28 PM
Big Ray 800's Avatar
Has a DS 800 Turbo Nitrous EFI money eating monster!
I just take them to the local tire shop and have them pop them off the bead
Old Apr 14, 2009 | 11:03 PM
wyowheeler's Avatar
Air it up and that will keep the sidewall from rolling. Stay back when it finally breaks!
Old Apr 14, 2009 | 11:32 PM
2006ds650xrider's Avatar
thats sucks i just bought some 00 stock ds rims to put my mud tires on and i cant get the bead to stay
Old Apr 15, 2009 | 09:30 AM
  #15
Sport400inOH's Avatar
I finally broke the bead this morning...I had to dremmel through several layers of steel cords and then use a screwdriver to chisel the rubber up in one spot. Then my HF tire changer popped the bead and the tire took a whole 23 seconds to remove.
If you want the bead to stay, clean the rim and the tire really well - remove the valve stem, then spray some windex at the bead (all the way around) and inflate to 40-50 PSI with a hefty compressor (One that has a reasonable tank). You will hear the beads "pop" when they are properly in place. As a safety measure, do not go above 50 psi and be sure to keep your face and any valued body parts VERY far away.
P.S. I did try adding a little air and breaking the bead that way, too. The sidewall just kept giving in. I only used a couple psi, maybe that wasn't enough.
Old Apr 15, 2009 | 06:42 PM
  #16
its good to see that you got that stubern azz tire off.
as for my tires i had the big o near me do it(3 times already) and i even paid 20$ but the one rim and tire wont seat they've even done some grinding on it but i think it might just be junk.
Old Apr 16, 2009 | 08:14 AM
  #17
MRDS650's Avatar
Canadian and Proud of it !!!
The best way to break beads on ATV tires when they are tough is to put a little air back in them. This way what you are using won't slide off the sidewall. We do this almost all the time. I own and Run a Goodyear Tire shop, ATV tires - speciallity the DS ones with the fake bead lock can be nasty.
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
JackTheKing
Jul 14, 2015 09:09 PM
jettman
Jul 6, 2015 12:16 PM
Mphillips
Jul 2, 2015 07:20 PM
