few questions on parts
i think i just found a cheap used one how much are they usually?
and i think im going to get a k&n filter should i leave the lid off the air box or remove the entire air box and do i need one of those prefilter or whatever they are called?
Thanks
Thanks
Due to the nature of the carb, removing the airbox lid will cause you problems, unless you make some modifications (Search for OMR Carb mods).
As far as the Ebay cap, I have it and it did make a hefty difference over stock (You will need new silencer packing material and you will want to keep the baffle installed as without it truly hurts the rider's ears). I also have the Dynojet Kit (Moose racing jet kit is exactly the same) and the K&N Filter with an outerwear.
As far as your Big Gun Pricing for the Rev Box (I have that, too, and love it!) , Look in some sellers stores on Ebay - some are much less than the one that you posted.
If you don't need top end speed (I almost never wind it out in 5th), drop the front sprocket a tooth to gain some additional acceleration. If you are a tub like me, drop it 2 teeth! :-)
would it be worth removing the lid and doing the carb mods and im geting the dyon jet kit would that do anything as far as fixing that?
and im 6'4" bout only 170 lbs and i deffinantly want to keep my top end so im going to keep my sprocket the same unless if i get some different sized street tires
i cant find any cheaper ones in the ebay stores it seems like im blind or something can you find one that is less?
#15
thank you
http://www.dynojet.com/pdf/Q702.pdf
#16
By all means do the OMR mods. If water and mud aren't an issue you can shave some weight by losing the airbox and snorkels altogether. Most of us out West that primarily dune don't run the box. I believe OMR covered this in his write-up.
Can't hurt to put the Outerwear on regardless of which way you go with the airbox.
#17
#18
