Gear shifting issue ?
Old Jul 14, 2009 | 11:23 AM
crs76's Avatar
Default Gear shifting issue ?
I have a Bombardier Quest and it needs to be rocked back and forth to get it to shift into another gear, my dad had a similar problem with his Outlander.
I understand there was a thread on here that mentioned there is a different bearing that can be used on the clutch that will eliminate that.
Does anyone know if the bearings are the same for different models ?
Is the outlander the same as the quest. They both have the 6 arm clutches.
The dealer said it needed a shim ?? The new bearing did the trick on my dads machine.
thanks, crs
Old Jul 23, 2009 | 12:13 PM
fastestrider's Avatar
not sure about the quest but i know where you can get the bearings for the outlander. go to vxb.com and its part #6808rs. the size is 40mmx52mmx7mm and you need 2 of them about $30and takes abut an hour to an hour and a half to install. i know i have the same problum with my 09 650 maxx.
Old Jul 28, 2009 | 09:40 AM
crs76's Avatar
Thanks for the measurements, that will help.
Old Jul 28, 2009 | 12:05 PM
Can Am Beginner's Avatar
Sometime I have to rock my 650 outlander to get it in park. Did yours start out this way?
Where did you get that buck, and is it a whitetail?
Old Jul 29, 2009 | 02:25 PM
oldboy's Avatar
Can Am Beginner
Your 650 Outlander, needs the bearing change. Talked about in this post ( 6808 ) There is a post that tells you how to change them
Check out the post " Some Questions " There is a video that shows you how to change them.
Yes, the buck is a White Tail, crs76 can tell you the rest.
Old Jul 29, 2009 | 08:12 PM
Will you hurt the machine if you don't change the bearing right away?
I said earlier the machine works, but when I go from H to P or R to P I have to rock the machine sometimes. I want to be proactive, but I have the disease "fundsrlow"
Old Jul 30, 2009 | 10:08 AM
oldboy's Avatar
That is the wy BRP made it, the bearing change, fixes the shifting issues. I would have to think it will give you a longer life of the Quad. The bearings are $14 ea, the installation is not that hard.
Old Jul 30, 2009 | 11:12 AM
Default Good Decisions?
Thanks Old Boy!! I guess for the money it is something I should do. I bought the quad for $5,000 with 232 miles and didn't expect to have to do much work, but everything can always be improved. The money broke the bank for awhile, so I was trying to hold off on putting more in for awhile. Since it seems you know a lot about this type of quad, did I get a good deal? The Brand new 07 650 outlanders were going for $6500 firm, plus tax, so I bough this one in February off the internet.
Old Aug 3, 2009 | 11:18 AM
oldboy's Avatar
5 g's would be a good price. We just bough a new 07 650 for my wife, they still have some cary-overs it came to $6000. but we got a 3 year warranty.
skinnyr6
Aug 25, 2023 02:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Unzzy66
Jul 11, 2015 10:01 PM
sara durrant
Jul 6, 2015 05:32 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
