2002 Ds 650 Baja CHAIN SIZE
Old 05-06-2010, 10:18 AM
DSengineer's Avatar
Has been here a long time!
RK, EK, DID are all good chains.
Old 10-18-2010, 03:42 PM
luis renteria's Avatar
Is 15/42 best gear ratio 4 racing a ds650?? N do u know wat I should do I can't adjust my chain no more I have it set on the tightest possition n its still 2 loose?? Should I just cut it??
Old 10-18-2010, 04:15 PM
DSengineer's Avatar
On a stock bore DS I always found 15/42 to be the optimal gearing for my weight ~180lbs while out in the dunes. The bigger heavyweight guys tend to go even lower 14/40 while the big bore guys can go even taller than stock gearing. There are a lot of factors that go into determining the best gearing
-Rider weights
-Motor mods if any
-rear tire diameter
-what kind of racing are you talking about? Flat?, Hill?, 300ft, longer
Need more info...
Hankey Pankey
05-01-2018 01:33 PM
Hankey Pankey
08-17-2015 05:01 PM
coolguy420
07-10-2015 01:17 AM
cSchwartz
07-09-2015 02:43 PM
MNatv89
07-07-2015 11:36 AM
Quick Reply: 2002 Ds 650 Baja CHAIN SIZE
