tm45?
Old Jan 8, 2011 | 11:37 AM
stunner4206's Avatar
Question tm45?
im real close to getting a tm45 for my ds650 and was wondering what you guys think about this mod? is it worth the 650$?? also would you go with keeping the stock snorkel with a k&n or would you go with the k&n mounted directly to the carb?? any suggestions would be appreciated... thanks
Old Jan 8, 2011 | 03:54 PM
THEBOM's Avatar
THEBOM Racing. If it don't scare you a little, it's not going fast enough !!!
It's a good one but you have to open up the intake to match or your wasteing the bigger size. K&N direct mount is good for hp over the snorkel. Just got to have every thing tune correct.
Old Jan 8, 2011 | 07:18 PM
Yeah I'm planning on getting it thru Ron wood and it will include the intake manifold. I want more power and better bottom end. I currently run a pro circuit t4 slip on k&n filter outerwears lid big gun cdi 15 tooth front sprocket and my stock carb is jetted properly. I do like the power its putting out but more is always better I'm looking to add the tm45. I do have a shop that will dyno tune the bike to perfection... would you do it???
Old Jan 23, 2011 | 06:47 AM
Hightower's Avatar
My tm45 is still working perfect after over 9 years and a thousand hours, never looked backed and no regrets, its a great carb built to last and performs awesome, the accel pumper is the shiznit for hopping ruts roots and logs.
Old Feb 6, 2011 | 06:18 PM
GroundSpeed's Avatar
Im thinking of putting on a slip-on pipe(stuck between HMF comp. w/ stage 3 insert or Yoshi) and probably stage3 dyno jets (again dont know enough between stage 1 or 3 jets) and a uni air filter. Im want a tm48 carb (with 48 intake) but im wondering if that will be to much or will the tm45 be better for my future setup. also I will still be using the sealed air box and snorkles because i do every type of riding from the track, to mud/ trail etc.
sandcrazy10
Mar 27, 2004 05:05 AM
222
Feb 19, 2004 10:35 AM
GLWBEAR
Jan 31, 2004 02:25 AM
DezNutz
Sep 27, 2003 06:42 PM
Birdoprey
Mar 31, 2003 10:19 AM
