2005 330 outlander rear differential / drive shaft problem
Old 05-27-2013, 12:06 AM
js380's Avatar
Question 2005 330 outlander rear differential / drive shaft problem
Hey I just acquired a 2005 330 outlander 4x4 and I am noticing a grinding/clunking noise from the rear differential area while pulling it into my garage. so i put the atv up on a jack and noticed lots of slack at the rear of the drive shaft going into the differential, even the rear break rotor moves forward/back due to this slack. anyone have any tips/advice on what this problem is and where should I begin to sort this issue out? Thanks in advance.
Old 11-04-2019, 08:13 PM
PtMowerMech's Avatar
Was hoping someone had an answer to this, cause I'm having the same issue. Clunking noise. A lot more so when I'm turning left. It's an 06 800 4X4.
tporath
07-11-2015 12:31 PM
BRPLOVER
01-15-2007 08:05 PM
TinkerToy
10-17-2003 11:18 PM
Quick Reply: 2005 330 outlander rear differential / drive shaft problem
