DS650 Problems Help??
Old Mar 8, 2014 | 09:23 PM
bradmullins15's Avatar
Default DS650 Problems Help??
Hello everyone I acquired a 2003 Ds650 Baja the battery was dead but it boosted off fine and I rode it for the test ended up getting it. Well before I rode it again I made sure to buy a new battery. After installing the battery it ran fine for that days play around ride(30 min max). About a week later I went to ride it again and the battery was completely drained wouldn't even turn on the lights. While having a battery charger/booster hooked up it will only run while the starter is held. If you do not hold the start button then it just spits and backfires. Was the battery I replaced the old one with just bad or is there something electrical that caused the battery to drain? Also why will it only run with the start button pressed? Any help would be much appreciated I am lost!
Old Mar 10, 2014 | 05:37 PM
justme23005's Avatar
Charge the battery & check the battery voltage while its running... Probably a bad regulator.
Old Apr 28, 2014 | 12:33 AM
Gollum Smeagol's Avatar
I am the new owner of a DS650. Supposively problem free quad has now turned into a huge headache. A little background on it, previous owner purchased it used from a dealer.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
