Can Am Renegade Ignition Switch Programing
Old Mar 28, 2019 | 10:41 AM
stevodee's Avatar
Default Can Am Renegade Ignition Switch Programing
Hi All,
I have a Can Am Renegade 2010 500 and the lights don't work, high and low. I checked all fuses and relays and all appear good. My ignition switch however feels like its not working right. There is a position on the ignition switch for lights, so, I am thinking of changing the ignition switch. Will I need to reprogram the key if i use the original key and a new switch. Any help is greatly appreciated.
Thank you,
Steve
Old Apr 1, 2019 | 08:58 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Can-Am ATV Forum is the place for your answer. I think the switch will come with a new key and your old key will not unlock it. The keys are programed to the ECU not the switch. I could be wrong so go asked at the link I provided.
Old Apr 1, 2019 | 09:07 AM
stevodee's Avatar
HI, I believe the keys are interchangeable. I don't see a link. And thank you!
Old Apr 2, 2019 | 08:37 AM
Dazeys's Avatar
Can-Am ATV Forum
Old Apr 3, 2019 | 11:05 AM
stevodee's Avatar
HI, So the final solution was a bad ignition switch that fixed the light issue and I did not have to reprogram the old key. It fit perfect in the new ignition.
Thank for the responses.
AC-Greeny
May 8, 2016 04:03 PM
ezhoops
1) Engine problems..
Dec 7, 2011 09:43 PM
Pull
Feb 3, 2009 12:09 PM
Auztone
Jul 18, 2008 08:20 PM
DaSandBomb
KTM
Aug 19, 2003 02:11 AM
