Are A-arms interchangeable between Baja and Original DS??
Old Nov 7, 2001 | 01:35 AM
  #21
Knutz's Avatar
Wheel offset will not change the travel. Arm length would, but the arm length is the same.
Old Nov 7, 2001 | 01:45 AM
  #22
ezwheeler's Avatar
any time the wheels are moved in or out will change wheel travel
Old Nov 7, 2001 | 02:00 AM
  #23
Knutz's Avatar
I hate to tell you this, but due to simple geometry, the plane on which the wheel moves through offset changes is not the same as the plane the arm length effects travel. You could put a 4' wheel with full possative offset, and the travel would be the same as stock, but if you use a 4' a-arm on the quad you will gain alot of travel. I'm not trying to be a smart ***, but your arguing a point that you happen to be mistaken about.
Old Nov 7, 2001 | 02:17 AM
  #24
ezwheeler's Avatar
OK you are right.an offset wheel changes the leverage that the shock has to react to.i don't mind being corrected.thanks for the info.when is the 830cc kit coming out.
Old Nov 7, 2001 | 02:20 AM
  #25
fourlix's Avatar
Knutz, you are correct sir! It is the distance from the A-arm pivot to the ball joints, which forms a parallelogram with the upper and lower a-arms, that determines the wheel travel, at least as far as this arguement is concerned, there are of course many other variables such as clearance and shock travel, attachment points and overall geometry. But Wheel travel is not affected by wheel offset in the case of double a-arms. Think of those A-arms forming that parallelogram going up and down, whether the wheel is sticking out or tucked in, it is still going up and down the same amount.[img]i/expressions/face-icon-small-cool.gif[/img]
Old Nov 7, 2001 | 02:30 AM
  #26
ezwheeler's Avatar
I was not aware we were having an argument.i would call it a discussion that i admit i was mistaken.
Old Nov 7, 2001 | 04:25 PM
  #27
Need4Speed's Avatar
I stand to be corrected. I forgot that they measured the travel by how far the wheel itself travels. I was thinking of valving and the sprinng lentgh.
Customer Service #1
May 15, 2020 08:46 AM
akguy31
Aug 31, 2019 04:34 AM
Impalaman
1) Engine problems..
12
Nov 8, 2015 07:17 AM
salixair
Nov 3, 2015 08:25 AM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
