RonWood tach?
You need make some 1/2inch spacers to go under the lower 2 screws to raise the dash up so the tach can clear the headlight, or the tach will hit the headlight(ace hardware usally carrys plastic spacer material just cut to length))I used a hole saw to cut the hole then a rotary sanding wheel to fine tune the fit.Once the tach is in position,I just used black silicone to hold it in place(on the back side).
Note: the upper dash screw is in a slot so just slide the dash up and re-tighten
Jeff
Jeff
Logan Collins
09-05-2015 08:03 PM
cody500ho
14
08-14-2015 05:03 PM
