DS jetting/mods data
Old Sep 17, 2002 | 10:07 PM
  #111
buttfungus's Avatar
DS jetting/mod info..
Biggerisbetter,DemonDs,ds650racer,918staxi...whew! ! Changes made! Thank you, drive through please!
Old Sep 30, 2002 | 02:32 AM
  #112
BlackHawk's Avatar
Now that I've finally got my DS dialed in, I'll add to the fray:
BlackHawk
2001
Black
Stock CDI (need to get a new one)
K&N in the airbox with lid off on snorkels plugged
Stock Carburetor
White Bros. E-Series exhaust
Dynojet 190 main
Stock Pilot Jet (45)
Dynojet needle in the third slot
air/fuel screw is 3 turns out
nothing internal to my engine
current jetting is for 3000' elevation Gorman, CA / Hungry Valley
Stock Suspension
normal gearing
IMS tank, 22&23" holeshots
Old Sep 30, 2002 | 10:00 AM
  #113
buttfungus's Avatar
BlackHawk, thanks! info added....
DS jetting/mod info....
Old Dec 19, 2002 | 07:05 PM
  #114
buttfungus's Avatar
Default DS jetting/mods data
http://home.swbell.net/tharthun/home/dsdata.htm
Vegas650,
Page updated:
Old Dec 19, 2002 | 08:37 PM
  #115
DSWOLF's Avatar
Did everybody in the ds data page updated,if not please do it it could help your fellow ds riders whit tips......
Thanks.
Old Dec 20, 2002 | 12:13 AM
  #116
lilnotts's Avatar
could you please add ski kit, 22" Realtors on ITP .190 Aluminum Rims,22"Excavators on Stock Rims, Uni Filter in the Box,black scott grips,MBRP Power Tech 4 exhaust
yellow grab bar, bumber,thermostat cover,motor lettering,rad guard, shifter,brake lever,
thanx alot man
Old Dec 20, 2002 | 02:42 AM
  #117
DuneMe's Avatar
Steve:
It has been a while since I have updated too.
me: DuneMe (Formerly, The Faster The Better) - Mark
year/color 2001/Yellow
cdi Ron Wood
airbox K&N mounted on carb with outerwears
carb Mikuni 45mm
exhaust Pro Circuit T4 - Slip-on
main jet: 150 Mikuni - 45 mm carb
pilot: 45 - 45MM carb
needle Stock for the Mikuni 45
air screw 2 and 1/4 turn out
internals: Team Pami 11:1 piston, Race 1 Cams, Pami Race Head, Team Pami Head Bolts (hardened for less stretching.)
elevation 4000
suspension stock
gearing 15/42
Clutch: Pami - heavy duty clutch springs
Tires: 22x11x10-9 paddle Extreme Haulers
Other: Baja Tach and Lights, Diamond G Heel Guards
Thanks.
Old Dec 21, 2002 | 02:25 AM
  #118
buttfungus's Avatar
ilnotts.DuneMe:
info added:
jldominic
Honda Side by Sides
Aug 8, 2015 06:54 PM
Aug 6, 2015 11:49 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
KISSSOFDEATH
Apr 10, 2004 06:04 PM
AdamsBadDS650
Sep 2, 2002 10:42 PM
