guess I need more speed...
My riding buddy with the Raptor barely beats me right now in the 100 yrd sand drag 'cause my clutch slip situation, getting new springs soon and then problem solved I should hope, and now I see his postings on the Yamaha forum (eRAPTOID) about a cam, and a new headpipe for his e-series slip-on.
Doesn't it suck that we have to pay twice as much money to get even with a Raptor?
Two new cams (with springs,or without), or a high comp piston - what should it be for me?? I can look up old posts and get my answers, but this is more fun...
Knutz is too busy, doesn't have time for everybody's questions. I wanna hear some smack from DS riders about the a$$ they kick with their mods.
The high comp piston is the quickest, easiest, cheepest thing for me to do, but where is the bigger gain - piston or cams/springs, or is there not enough noticable difference with just one and both at the same time is the only real gain? I don't wanna spend a fortune on overbores, just wanna work on it in my own garage...
I've decided that the best cams for me, based on my riding areas, terrain, style, etc., is a "sport" style cam for maximum low and midrange, rather the highest lift for top end gain. If I go with this type of cam, are heavier and/or dual rate valve springs required, or are they just an easy "drop-in" at my next valve clearance check/adjustment.
I didn't have to adjust valves at my last check, but the intakes were .002", so I'd expect to need thinner shims next time, and I might just go with cams while I'm at it.
Hightower give Sam Coe a call I have his cams and springs great all round power. It come with under buckets for around $500.00
http://www.samcoeperformance.com/
Customer Service #1
05-15-2020 08:46 AM
