Valve clearance too small??
Old May 18, 2002 | 08:40 PM
Hightower's Avatar
Manual says .004-.006. My exhaust valves are in spec, but my intake valves have gaps of .003 and .002
My question is :
Will things wear to increase this gap over time, in which case no adjustment is really necesary, or will the valve "cup" in the seat over time and decrease this clearance, in which case adjustment is needed.
Old May 18, 2002 | 08:55 PM
DSjockey's Avatar
If it were mine I would change the shims to obtain proper clearence and recheck it towards the end of the season
Majorecho's Avatar
my valves were cupping when I redid my head and my exhaust valves were looking a little burnt. ( maybe the NOS) I didn't have any clearance on one of my exhaust valve and the intakes were .001 and .002. I gave myself a little more clearance then spec with the rebuild and hopefully I won't have to make any changes for a year or two.
Old May 18, 2002 | 10:21 PM
Hightower's Avatar
DSjockey - two new shims are getting ordered - I felt the same way so I just finished removing and measuring them.
Majorecho - do you suppose the added pressure from the NOS was cupping the valves, or do you think everybody's valves cup over time and cause clearance to decrease?
Talk about tight machining tolerances - all four of my factory valve shims are the exact same thickness, to the ten-thousandth!
Old May 19, 2002 | 12:23 AM
Majorecho's Avatar
Hightower that is a great question, one that I could only speculate about seeing that I have no Idea what my valves and seats looked like befor running the NOS.
anybody else?
QuadRiders
Oct 22, 2015 04:13 PM
firsttimerider
Sep 26, 2015 01:49 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
