DS650 Float Bowl Screws for the Asking
Aa a follow up a prior reply I made on another post. If any one would like a set of the stainless steel hex cap screws for the float bowl that have been discussed here before, email me your name and address and I'll mail a set to you. I have 73 of the 10mm and 91 of the 12mm screws left. They sure are alot nicer to work with than the stock phillips head screws that seem to strip out on everyone when you remove to float bowl. In case you missed it in prior posts you will need 3 10mm and 1 12mm. The 12mm is the screw you use for the idle adjustment **** bracket.
Swoopman,
A generous offering there...you must be getting hit with alot of PMs. I would take you up on the offer but I have a set waiting for me at home from Buttfungus--Thanks again, Steve...and props to your wife for sending them!
Jim
Jim
Oct 10, 2015 10:20 AM
