Best slip-on exhaust?
I too have the Pro-Circuit slip on.
I was supprised to learn that it does hit the swing-arm. Mine has a very small dent in it way in the back / under.
You are going to have to get some very big air to do much damage to the pipe. I accidentially went off a dune once and flew about 35' with about a 15' drop. I am sure this is where it got bent. Luckily, I was able to land without falling off the quad. Sometimes luck is far better than skill.
I would go with the Pro-Circuit again but, would check out the Yoshi and the CT pipes first. The Pro-Circuit is less than $200 I would guess the Yoshi and the CT would be around $400-$500. Not worth the extra money to me IMO.
I think FMF makes a pipe that is approved for the Oregon Dunes (noise restricted.) If you are concerned about noise at all. It is the Q series. I am not sure if they make one for the DS yet.
Whatever you do make sure the pipe is USFS approved Spark Arrestor. A few pipes do not have the spark arrestor and you will not be able to ride in many areas without it.
#16
MadBaja819,
I read you purchased the 14" FMF Titanium-4, I really like that one but am worried about the noise level. Can you compare the noise of yours to any others? I hate to go to the 17" for noise level but loose on the power. Plus I really like the size of the 14", small, dosen't extend past the grab bar or hit the swingarm. I really like the looks also.
#17
mrtidy
02-03-2016 05:00 PM
Quadzilla Heritage
09-25-2015 01:39 PM
