What should i do next?
If you get a Dynojet kit ($50) and install it by their instructions, you will instantly be amazed with your new throttle response. For even more power gains, remove your lid on your airbox. If you do remove the lid, use Stage 3 instructions, if you stay with the lid because you ride a lot of creeks then use Stage 1 directions. I'll bet you a cold beer you'll love it and do not go back to the stock needle. Wheelies will be much easier, better low end through better throttle response, guaranteed. Order direct from Dynojet website, or get it from Dennis Kirk.
Then, get yourself the RWR CDI box ($300). Its not just a rev box - it boasts performance increases throughout the rev range, achievable by advancing the ignition timing several degrees beyond the stock box. You've already got the tach, lack of rev limiter is of no concern.
After this stuff you'll start getting addicted to drag racing, and that's when you'll begin to realize that your clutch is slipping from the extra HP you've added, combined with the speed shifting you're trying to master. To combat this you'll need heavy duty clutch springs - available from Pami ($50), RWR ($24), Alba, Barnett ($17). After installing the springs (its easy) you can now change to a semi-synthetic blend oil, which would only cause worse slipping without them.
Do all the above and you may have a chance at beating me!![img]i/expressions/face-icon-small-happy.gif[/img]
Don't worry about the clutch springs yet. I have Ron Woods Stage 1 kit and I have yet to notice any clutch slippage what so ever. Don't fan the clutch like a 2 stroke and you will be ok. You don't need to fan the clutch anyway with all the torque these monsters have. He is right about the Dynojet kit though, you should definatley go for that! Also gear down one tooth in front, go to a 15 tooth sprocket and you will notice a huge difference also. The Dynojet kit and a 15 tooth sprocket are the first things besides a pipe that you should get. You can pick up the Kit and Sprocket for about that $100.00 bones you have. Good Luck, have fun, & ENJOY!!
about the springs - the only slippage I've ever had was drag racing, particularly with 10 paddle haulers in sand, 'cause that's when you're revved the highest while shifting...normal trail riding has never revealed any slippage in my clutch. the slippage that did occur while dragging caused premature wear, and I had to replace my fiber disks after only 60 hours on the motor.
Removing the lid worries some guys, because they're afraid getting crap on their filter, but unless you really like spinning around in puddles all day its really not a big deal. I run lid-free, and croos creeks all the time, but I cross them slow and keep major splashing to a minimum, and have never gotten a drop in the box. I leave the drain cap off the bottom too, so if a splash does get in then it can run right out. Outerwears is a must if you take the lid off. Power gain from running with no lid is noticable, just follow stage 3 instructions in the Dynojey kit, rather than stage 1, or you'll be too lean everywhere.
Clutch spring installation
The instructions sound extensive, but once you start you'll see its no biggie.
