leaking anitfreeze
Old Jul 14, 2002 | 04:06 PM
sevenac's Avatar
i got my ds a couple of weeks ago and just went on my second weekend ride. I noticed later in the day that i was dripping antifreeze from underneath the water pump. I thought it might be my radiatior hoses but found that there was a small hole underneath my pump. When i shut down my engine it would stop in about 5 minutes, but then continue as soon as i started up. I have no idea what the problem is. Can someone help me.
Old Jul 14, 2002 | 04:39 PM
Batoutahell's Avatar
The water pump seals are leaking.
Should most likely replace the seals and shaft at the same time.
Others have done this recently, so maybe they can tell you more.
Bat
Old Jul 14, 2002 | 04:51 PM
BillDS650's Avatar
sevenac sounds like you need to replace the seals on the water pump. http://faq.f650.com/FAQs/Water_Pump_Seal_Repair_FAQ.htm
Old Jul 15, 2002 | 05:24 PM
Hightower's Avatar
More than likely the shaft will be scored where it spins in the seals - replace it too. The seal are $4.95 each - you need two, and the shaft is $12.95 at the dealer. My got scored from sand introduced into the weaphole underneath - I put a tiny (4mm) hose barb here (drilled and tapped) and ran a clear hose from it to the rear, beside the carb drain hose. This will prevent future contamination.
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
