Engine dies/stumbles when doing a wheelie
Old Aug 29, 2002 | 05:59 PM
Rockey's Avatar
I cant figure out what the problem is, but when I climb big hills or do a wheelie the engine will start to cut out and die altogether if the front end doesn't come back down quick. Is this a float level problem? Is it too high or too low? Im guessing its too high because it seems as if it flods the engine out. Any help?
Old Aug 29, 2002 | 06:22 PM
Hightower's Avatar
I'd agree. After I get home, I'll look up the float level spec in the shop manual and e-mail it to you. Ernie's problem was the same thing - he, or his mechanic, must've accidently knocked it off changing jets.
Old Aug 30, 2002 | 12:58 AM
DSWOLF's Avatar
I bet your carb is dirty??
Old Aug 30, 2002 | 03:58 PM
eRAPTOID's Avatar
Yeah Rockey, the uphill and wheelies would do me the same way after the rebuild. I jetted down cause I was really rich, and it was still there. After I went back in there and checked them, one was off quite a bit (2 carbs); the other not too bad. I raised the level of the floats by 2-3mm from specifications. My problem seems to be resolved now! I am certain now that it was the floats! I just need to find me a long steep hill to FULLY test it....
That is where I would start Roc, it is fairly easy to knock them out of adjustment if you've been in there several times in a day (like i was).
Good luck,
"TOID"
(edit) I thought the same thing too, that it felt like it was flooding out. That's why I jetted down first, but my problem was still there, UNTILL I moved the floats UP/HIGHER. It's not there during wheelies at all anymore, or small hills (around my house).
Old Aug 30, 2002 | 04:05 PM
Rockey's Avatar
I tried every float level i could last night to no avail. I'm going to buy the Lectron and take this stock carb and throw it as far as I can. I'm glad it worked for you though I know how frustrating it was riding up those hills having the damn engine sputter. I hope it doesn't ruin my weekend coming up! You said you had to raise the float level, right? Maybe i will try one more time before i pee on it and light it on fire.
Old Aug 30, 2002 | 04:49 PM
DollarBillz's Avatar
you need to ajust the needle vavle move it down
Old Sep 3, 2002 | 02:36 PM
Hightower's Avatar
Rockey - float level should be 10mm - with carb upside down, measure from bowl seat to bottom rdge of float. Bend contact tab to set it at 10mm +/- .5mm. if you still have the problem after this, pee on it!
I don't know anybody that has ported without doing other stuff too, so you're in new territory on your tuning!
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
Jul 30, 2015 09:39 AM
black_thunder
Jul 26, 2015 09:23 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
