Carb Problems please help!!
Old Sep 8, 2002 | 08:13 PM
Bom2000's Avatar
I just put in my TM45 last night. I started it up and it sounded like it was idleing high. I shut it off and now it won't start at all. Has this ever happened to anyone if so can someone help me before I wind up dropping it off at the shop. Thanx
Old Sep 10, 2002 | 01:35 AM
hinglbyds's Avatar
I hope this helps.... make sure the air/fuel screw (left side by fuel line) is turned out 2-3 turns. Check the idle ****. It's easy to check if the trottle cable is disconnected and you can look down the carb throat. The slide should have between 1/16 and 3/32 gap at the bottom. It should start and the you can play with the idle and the fuel/air screw and jetting. Check out this web site: http://www.mikuni.com/ It gives some excelent tuning tips.
Is this th RWR carb?
Old Sep 10, 2002 | 08:56 PM
Bom2000's Avatar
Yeah it was the RWR carb. I took a look at the air screw and it was about 6 turns out and the idle was all the way out I adjusted those and it started right up. Thanx for the advice.
Old Sep 11, 2002 | 12:32 AM
hinglbyds's Avatar
Good... I like it when things work right. Good luck!
Old Sep 11, 2002 | 10:06 PM
Bom2000's Avatar
Thanx
Ty Speece
Jul 2, 2015 04:59 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
kevbowe
Jun 1, 2015 01:17 AM
