urrrgh stock grip removal :(
Old Sep 16, 2002 | 09:01 PM
Jimbostew's Avatar
well i got a new set of grips for the pig and after hacking one side nearly off with a boxcutter i figured out that bolts attached to plastic sleeves hold them on.Question is how do i get the grips off the sleeves or how do i fill that "gap" that was left after i took off the grips? thanks ahead.
Old Sep 16, 2002 | 10:16 PM
mxzxracin's Avatar
I did the same thing![img]i/expressions/face-icon-small-smile.gif[/img]
But i tryed and tryed to cover that gap, but every thing i did failed. So i just used lots of glue aroung the gap so it cant come loose. I couldint tell the gap was there, but now i have new bars, so i dont have to deal with it now.
Good Luck
Old Sep 16, 2002 | 10:24 PM
lilnotts's Avatar
ya i had the same problem, my bro just pust a piece of wood in there, n cut it so it would fit correctly
Old Sep 17, 2002 | 01:38 AM
918sTaxi's Avatar
At first I tried pvc pipe. It worked ok but I just decided to get some new bars. I got the red moose bars from rmatv for 16.99. It was well worth it.
Old Sep 17, 2002 | 02:58 AM
BlackHawk's Avatar
I think 918sTaxi $16.99 moose bars are the best fix. I might have to order some of those, though, not in red. Maybe Blue. Do the $16.99 moose bars you bought rub the tank at all, or do they have good clearance?
As far as 'fixing' the stock bars, I have larger hands than most guys, so I was looking for a grip with the largest outside diameter possible. The thing I found that works best also solves the stock bar problem. The cheap (like $1.99 cheap! per pair) foam grips I have also have a solid plastic tube that goes on the bar and the foam grip onto that.
Old Sep 17, 2002 | 09:40 AM
mxzxracin's Avatar
My moose bars rub only on the left side of the tank not on the right...
Old Sep 17, 2002 | 12:46 PM
918sTaxi's Avatar
The bars rub hardly at all, I've never noticed acually. I did have to trim about 3\4 of an inch off of each side of the bars because my controls were pretty stretched.
Here is a pic of the bars.
Bars
Old Sep 17, 2002 | 10:13 PM
02bansheeman's Avatar
they make spacers to left the aftermarket handlebars up not to rub
Old Sep 17, 2002 | 11:07 PM
BlackHawk's Avatar
For anyone who lives in Southern California, Chaparral Motorsports is having their once a year parking lot sale. I just got the flyer today, a couple of the vendors have aluminum handlebars listed for under $20. As well as all kinds of other gear. I think I'll hold off on the steel moose bars until I see if any of these guys have bars that I want.
Anyone who can make the trip to San Bernardino, CA should make the trip over on the 28th of September. I know a few people who get there at like, 4:00am just to get a good spot in line. I did that the first and second year, but after that I decided I like sleeping in better.
slowgsxr97
Mar 18, 2022 03:40 AM
Cantbuytime
Aug 16, 2015 09:13 PM
erntee61
Aug 9, 2015 02:54 PM
Stirling
Aug 9, 2015 01:49 PM
cSchwartz
Jul 12, 2015 07:42 PM
