changing cams and piston
Old Oct 14, 2002 | 07:09 PM
SANDMAN430's Avatar
Default changing cams and piston
got cams springs and a piston, and wondering how hard it is to do the work myself. i have a shop manual, and the tools it seems. kind of would like to do it myself, if it isn't to bad, i've done alot of 2 strokes . and a couple of cars but never a 4 stroke bike . but oeverall the manual looks clear. thanks for any input.
Old Oct 14, 2002 | 07:30 PM
glamisds650's Avatar
no, the job isn't too bad at all. just watch the torque specs.
also you will need to build or buy the special valve spring compressor, but thats it as far as specialty tools.
the only real pain i had was getting the head off ( because of clearance)
good luck.
tips:
don't reuse the nuts that hold the head on, they will strip out.
don't forget proper break-in after the hard work.
Old Oct 14, 2002 | 11:10 PM
lilnotts's Avatar
when my bro n i rebuilt my old 84' lt185 i found the hardest part is setting the timing, but i never changed the valves myself
Old Oct 15, 2002 | 12:12 PM
BillDS650's Avatar
Glamisds650 you are talking about the 4 large nuts only or due need to replace the four smaller bolts all so
Old Oct 15, 2002 | 09:03 PM
only had a problem with the four nuts[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 15, 2002 | 09:13 PM
BillDS650's Avatar
Thanks I have them on order.
Old Oct 15, 2002 | 09:53 PM
bill, i had the markings checked out. they are not hardened. they are your regular run of the mill flanged nuts. i guess they are that way so you don't damage the studs. cost should be about .20 a piece at the hardware store.
Old Oct 15, 2002 | 10:48 PM
BillDS650's Avatar
OUCH! I just paid $ 3.00 Ea
Old Oct 15, 2002 | 11:59 PM
sorry bill, i should have stated that first.
Old Oct 16, 2002 | 02:31 AM
ThePunisher's Avatar
Dont worry bill it is better you use the factory nuts. You will be hard pressed to find the right ones anywhere else. You need that flange on the bottom to keep from putting unnecessary strain on the head. You could crack it. Just remember one thing don't use any lubrication on those threads! Put the nuts on dry and torque them to 44 ft. lbs. do it 7 lbs. at a time in a cross pattern. And no you don't have to replace the other bolts. Gary at TVI has the new head studs in that are a hell of a lot better than stock but they are a little pricey though, but they would be worth it, I will buy some next time I need some head work done. Good luck. If you have any questions or problems you can pm me and I would be glad to help.
