best piston what is it ?
Old Feb 5, 2003 | 02:18 PM
cOoLdevil's Avatar
Default best piston what is it ?
hi all can any one tell me what is the best maker for hi comp. piston 11.5:1 that i can us it in the stock engien with out changing the stock bore and im thinking of the RWR piston for 240 $ any info needed and do i have to install valve springs and titanium returner and do i have to install a cdi for it and what all of you think a bout the cdi whech one is the best .
Old Feb 5, 2003 | 02:22 PM
KMDuner's Avatar
I would say that the Woods is a good one, Pami is a good choice also. I think that DuneMe may have a Pami 11.1 available, not sure though.
You don't have to change the CDI but I would highly suggest it. I would go with the Woods or Pami CDI
Old Feb 5, 2003 | 03:50 PM
SANDMAN430's Avatar
i have the woods piston and like it i can still run pump gas when just running with the kids. but i talked to gary at tvi and he has a few pistons to choose from. the springs don't have to be changed, but you might want to get a copper head gasket from tvi, if you want to do it later, stock head gasket was $48, the copper is $40 and i'm told you can use it again.
Old Feb 5, 2003 | 04:35 PM
cOoLdevil's Avatar
do i have to go for a biger carb or just stay with the stock one and what a bout the valve springs do i have to change it ?
Old Feb 5, 2003 | 04:41 PM
SANDMAN430's Avatar
you won't have to change any of that other stuff, you might want to later
Old Feb 6, 2003 | 04:15 AM
cOoLdevil's Avatar
what do you think guys does it worth to change it to a biger piston i only ride it for a long jurnys and some drag races and im not a fan of the engien mods and im a fread that will dameg the engien in the futuer
Old Feb 6, 2003 | 04:26 AM
Batoutahell's Avatar
In my opinion, if you are going to go into the engine, might as well go with piston and cams.
If you just bump the compression up a little with an 11.5 piston you will not feel a huge difference. With piston and cams you will feel a nice jump in performance.
However, with that you will probably need new valve springs, and will want a new cdi to use the new power, and probably a carb.
Just my two cents.
Bat
Old Feb 6, 2003 | 09:16 AM
SANDMAN430's Avatar
do the cdi first, if you go into the engine , do the cams and springs also, and you might want to port while your there also.
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
