3 mini's on my dash
Old Mar 13, 2003 | 02:10 PM
Shadow11m's Avatar
Default 3 mini's on my dash
Last night I installed 3 mini guages (volt, temp and oil) on my dash in the RPM spot. They are white face with a red,blue or green back light.
Too cool ! Not only does it look sweet,but fuctional. With all of the old topics I figured out how to use a t-connector to keep the oil idiot light.
The oil and the volt was a breaze ... working on temp.
Old Mar 13, 2003 | 03:01 PM
MudStud's Avatar
Well if you go and post something like that you better have some pics [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 13, 2003 | 03:13 PM
Shadow11m's Avatar
Pic's will have to wait.
I have too much on my plate right now ... new clutch,f-sprocket, oil,anti-freeze, solve hesitation problem , and carb work.
Oh and load the software for the digital camera on my laptop.
I promise that when I get finished I will post pics.
Old Mar 13, 2003 | 03:15 PM
Shadow11m's Avatar
oh .. I got them at O'rileys auto parts for $29.99.
They come in a kit of 3 , white face backlit and silver rings.
Old Mar 13, 2003 | 03:40 PM
Hightower's Avatar
What do you hook the gauges in to? What is the cost of the oil pressure sender, and where does the temp sender mount?
Thanks
Old Mar 13, 2003 | 05:48 PM
Shadow11m's Avatar
I do not have a tach so ... the kit comes with 3 guages in a bracket. I removed them so that it would look cleaner on the dash.
I bought a drill piece ($5) 1&1/2" from Home Depot and drilled 3 holes in the area of where the tach would go.
The entire kit was $29 with all parts except the 2 "T"s required for the oil and water. The one for the oil is brass and cost $2 and the one for the water is some kind of composite $2.
You remove your oil sensor mount the "t" ...screw one end into the case , your sensor in one end and the oil line in the other.
The same for the water temp except you just hook up the hoses. The sensor rides inside indirect end.
As for the volt meter you can hook it up to any hot wire.
I don't have patients for fabricating and this required almost none at all. Just like putting a puzzle together.
I will have to say the guages look best glowing red. The blue and green are to soft.
Old Mar 13, 2003 | 08:37 PM
VEGAS650's Avatar
Be careful with those cheap gauges!
I had an oil pressure gauge blow up on me while I was riding once and it ended up all over me.
I'm going to spend the extra money and buy a better quality unit soon.
Hey Jiminok, got those part #'s?
Old Mar 13, 2003 | 09:58 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Yes jim do share with us all[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 13, 2003 | 10:05 PM
lilnotts's Avatar
i put an watertemp guage on my dash that you can see here
Old Mar 13, 2003 | 11:18 PM
jiminok's Avatar
Sorry Al...totally forgot[img]i/expressions/face-icon-small-blush.gif[/img]
ATM-5421 Oil pressure, 0-100psi $45.95
ATM-5202 Cup for Pro-Comp (black) $15.95
1-800-230-3030...SummitRacing.com
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
salixair
Nov 3, 2015 08:25 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
MrTrashMan2U
Sep 9, 2015 11:44 AM
